How to read binary file in Matlab
"Hello all!
Labview 7.0 has an example "Cont Acq to File (binary).vi" log the PCI 6014 card and writes the data to a binary file. How can I read that
file in Matlab(6.5.0... R13)? Does anyone have a solution for this?
(4,375 Views)
Basically you can do it by saving the data in a file in MATLAB and reading it directly from LabVIEW, or vice versa. In MATLAB , the command "save" allows you to save the data in binary format (*.mat) or ASCII format. You also have an option of saving it in ASCII format using a tab delimiter between data points.
There is a knowledge base which talks in detail about how to share data in between labview and matlab Import data from labview to Matlab and vice versa.
Hope this helps. If not, please feel free to ask more questions.
Good luck and have a great day!
Koninika
(4,374 Views)
