How to read and write from XL file
HI ,
I wanted to read a data from XL file and write a data in XL file by generating a report .Can any body help me out.Many examples are available on discussion forums but when I try to save and run those Vi .I am not able to run Showing error .Please tell what is going wrong as I m having latest labview 8.6 .
Regards
Sharmila.karale
Message 1 of 10
(3,932 Views)
Is it possible for you to post the excel file and your VI which you have created to do a read/write?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 10
(3,931 Views)
Hi Adnan,
Here are the examples of Vi which I have downloaded from the forum for my reference
Regards
Sharmila.Krale
Message 3 of 10
(3,908 Views)
You didn't answer the question that I asked. I just wanted to see your excel file and your example application so I can understand the error you are getting.
Do you have the Report Generation Toolkit installed in your system?
Adnan Zafar
Message 4 of 10
(3,902 Views)
Probable cause: You have a different version of Excel than what the VIs were written for. The VIs use the "Value" property. Newer versions of Office (I think starting with 2003) changed this to "Value2".
You need to open the VIs that are broken, click on the run arrow to find the error, and change the property nodes to use "Value2".
Message 5 of 10
(3,873 Views)
Message 6 of 10
(3,816 Views)
Message 7 of 10
(3,815 Views)
Message 8 of 10
(3,813 Views)
OK... the VI you uploaded uses the Office Toolkit. But the libraries you had previously uploaded were something else. Now I'm confused.
Message 9 of 10
(3,802 Views)
You can try the examples given with the labVIEW 8.6.
just go to Help--> Find examples.
Message 10 of 10
(3,780 Views)
