How to read String-Array from TestStand-Global with "PropertyObject"
how can i read a String-Array from teststand-Station-Globals in the same way like teh attached screenshot?
I cant find a property called "GetPropertyStringArray"? Only "GetPropertyString".
How can i do this?
Thx for your help.
(2,675 Views)
Use the GetValVariant and the Variant to Data function. On your TestStand palette is the TestStand - Get Property Value function. Make the type String Array and then look at the block diagram.
(2,659 Views)
