How to re-trigger analog acquisition?
Why have you made it so complicated? I know what you are doing and you don't have to explain that. What I don't understand is your reasoning for doing it that way. Is the pulse connected to anything else?
Message 11 of 30
(1,358 Views)
Well, since I'm still fairly new to programming in general, things that are simple tend to be complicated..
Your guidance is appreciated.
Message 12 of 30
(1,356 Views)
I am not sure how else I would start acquisition if I need it to start on the falling edge of the counter if not for the trigger?
Message 13 of 30
(1,351 Views)
If you just leave off any triggers, it will start the moment you run the 'Start' vi.
Triggers are for if you want the task to start based on some external signal. Is there an external signal that you need to synchronize off of?
As for stopping, you will just need to gather data repeatedly and based on that accumulation decide when you're done.
Message 14 of 30
(1,346 Views)
You still have not answered the question of why you think you need an external trigger. A front panel Boolean can trigger the acquisition all by itself. One simple easy is to have an event structure with the DAQmx Read inside.
Message 15 of 30
(1,345 Views)
I thought I needed an external trigger (from CTR0 to PFI0) to tell the acquisition to start
Message 16 of 30
(1,341 Views)
No.
Message 17 of 30
(1,336 Views)
Let me rephrase - I thought that was a good way to ensure the acquisition starts as soon as the pulse goes low.
Message 18 of 30
(1,331 Views)
You are just talking in circles now. Somehow, you've become fixated on the external trigger. Unless you explain what is important about the external trigger (i.e. for synchronizing to something the counter is also driving), then I'll just assume you are making a beginner's mistake. I've asked you a couple of times what else the counter is connected to.
Message 19 of 30
(1,327 Views)
Counter is not connected to anything other than PFI0
Counter is driving the relay, but I thought it was best if I used the trigger to trigger the acquisition.
Alternatively I was thinking of running a physical wire to a digital line and reading the line status. If the line is 0, start acquiring and logging.
Message 20 of 30
(1,322 Views)
