How to "double" a 2D array?
This image shows the output array I want from an input array.
What is the best way to do this? (Best meaning fastest and most memory efficient).
I want to double the size of an image. I don't have IMAQ. I know about the zoom factor on image controls but that is not what I want.
LabVIEW 2012
Message 1 of 11
(5,233 Views)
Sorry I realized that I only did it one way.
Tim
GHSP
Message 2 of 11
(5,221 Views)
Here is one possibility.
Probably not the fastest and most memory efficient but it works.
Ben64
Message 3 of 11
(5,213 Views)
ok here is mine
Tim
GHSP
Message 4 of 11
(5,206 Views)
Accepted by topic author SteveChandler
      I did a solution using in-place memory, for best performance.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 5 of 11
(5,199 Views)
A small revision
Tim
GHSP
Message 6 of 11
(5,196 Views)
I whent for the IPE as well but used a logical shift to avoid the mutiply by 2s
OK Steve- Benchmark 'em
"Should be" isn't "Is" -Jay
Message 7 of 11
(5,189 Views)
and one more revision maks it so you can add how ever many copies you want.
Tim
GHSP
Message 8 of 11
(5,183 Views)
Thanks everyone!
I did some benchmarking. These are the results (vis set to high priority no debug)
Converting a 5000x5000 array, times in seconds
Luis          .43
Jeff           .43
Ben64       2.5
aeastet    .669
It is a tie between Jeff and Luis. Since the only way I can think of to decide who gets the solution is whoever posted first it goes to Luis.
LabVIEW 2012
Message 9 of 11
(5,168 Views)
     Thanks Robot Happy
      A more thing, you can enable loop iteration parallelism for get better time.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 10 of 11
(5,151 Views)
