How to put in different rows
I got a file where I swap from displaying the data in rows into columns by using transpose 2D array. The problem now is, it now shows everything in one row. How do I break it into several rows?
simplex-link  duplex-link
n1                n0
n0                n0
10               10
20               20
DropTail       DropTail
It should display:
simplex-link    n1    n0    10    20    DropTail
duplex-link    n0    n0    10    20    DropTail
But it gives me:
simplex-link n1 n0 10 20 DropTail duplex-link n0 n0 10 20 DropTail
Any advice where I did wrong?
Thanks 😄
Message 1 of 8
(4,191 Views)
Try this
Tim
GHSP
Message 2 of 8
(4,172 Views)
Accepted by topic author a01lida
Hi
I have LabVIEW 8.0 version. I try to understand your problem and make a new vi which reads all conc file.txt. I make vi which satisfied your requirement. You can have a look below imgaes
Viru
Message 3 of 8
(4,170 Views)
Based on the files posted, all you need it this:
Message Edited by Dennis Knutson on 12-02-2009 03:48 PM
Message 4 of 8
(4,147 Views)
Can you save it for 8.6?
Message 5 of 8
(4,141 Views)
I'm now trying to add more functions to Viru's solution
I'd like to add a constant at the beginning and somewhere in the middle of each row
What I got in mind so far is by using concatenate strings, concatenate the file and a constant then wire it to spreadsheet string to array , but it won't add the constant in each row; but instead, it only add at the first line
If I use loop, it still won't work right? As far as I understand, the file is read in a go, not line by line
instead of simplex-link n4 n3 10 20 DropTail, I'd like to do:
$ns simplex-link $n4 $n3 10Mb 20ms DropTail
Message 6 of 8
(4,130 Views)
Hi
I try to make a vi according to your requirement. I hope it works for you.
Please check the attachment.
Message 7 of 8
(4,083 Views)
Thanks 😄
The only thing is that, it will loop for 6x6 which gives out 4 concatenation without the data from the file (only $ns $ $..)
But I got around it by wiring the first for loop to a.txt (where it has n0, n1 - so it's read as 2x1) ; which ends up will loop only 2 times at the first for loop
I'm not sure if I'm making any sense here, but what I'm doing is, I have a file called a.txt which list out only n0, n1, another file, b.txt which only list out simplex-link, duplex-link etc. I then concatenate all the files giving me
 simplex-link n0
 duplex-link n1
 then I do another concatenation as Viru pointed out giving me $ns simplex-link $n0 etc
 Is there another way that I could try so that the first for loop would only loop according to the column number, not row without reading the number of row in another file?
Message 8 of 8
(4,065 Views)
