How to put a breakpoint inside a for loop.
Hi, I would like to know the steps to put a breakpoint inside a for loop.
Normally when I place a breakpoint on a for loop, the red border is in the outer area.
I am trying to put the red border inside the for loop.
Figure is attached for your reference.
Message 1 of 9
(3,349 Views)
Hi msabah,
place a breakpoint on a wire inside the FOR loop…
Message 2 of 9
(3,346 Views)
Hi GerdW,
When I place breakpoint on a wire inside a for loop, a red dot symbol appears on the wire.
Whereas I am looking for breakpoint with red border in the inner loop as shown in above post figure.
Message 3 of 9
(3,330 Views)
You have to decide, where you want to have your breakpoint.
It is either on a wire or structure inside the loop (with the appropiate symbol, usually a stop), OR it is on the loop then LabVIEW will stop on the entrance of the loop.
Regards, Jens
Kudos are welcome...
Message 4 of 9
(3,321 Views)
I want the breakpoint in the inner boundary of for loop as shown below.
Please tell the steps how to get this.
Message 5 of 9
(3,313 Views)
You can't do that specifically. Why is it that you want the red square inside the loop? What are you trying to accomplish? If you basically want to stop at when the loop iteration is complete you need to locate the wire that will most likely be executed last and place a break point on that wire. In your example below place the break point on the wire after the Add. The update of the shift register and the indicator will be the last thing to be executed in the loop.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(3,310 Views)
Hi msabah,
Which LabVIEW version was used to create that image?
Which LabVIEW version do you use now?
There probably was a (subtle) change on how the block diagram shows breakpoints set on structures regarding "inside"/"outside" structure borders!
To repeat all that has been said: Either set the breakpoint
  • on the structure border to stop when the structure is entered
  • on a wire inside the structure to stop inside that structure each iteration/execution
Message 7 of 9
(3,306 Views)
@GerdW wrote:
Hi msabah,
I don't know. It is taken from a CLD re-certification exam sample question paper.
I use 2019 LabVIEW version.
Message 8 of 9
(3,276 Views)
  1. Shift-right-click to get the diagram tools palette
  2. Pick the breakpoint tool
  3. Click inside the FOR loop.
Message 9 of 9
(3,267 Views)
