How to programmatically pause a VI?
How to programmatically pause a VI (pause a VI using a front panel button) as if execute Pause on toolbar
Message 1 of 12
(5,423 Views)
Message 2 of 12
(5,402 Views)
This is technically correct, but please note that since it's a blue node you won't see it as an option unless you have VI scripting enabled in your LabVIEW options.
Also it won't work when using the Run-time engine (i.e. if compiled into an EXE).
So depending on your intended use case for this node you may need an alternate solution.
Message 3 of 12
(5,378 Views)
Obviously we probably need a bit more information on what you are actually trying to do.
Do you want a VI to pause itself or control pausing from another VI?
Should there also be a way to programmatically un-pause? (obviously, a VI cannot un-pause itself, because it is paused, i.e. not running. 😄 ).
Typically, a pause is implemented as one of the states of a state machine.
Message 4 of 12
(5,320 Views)
Would it be feasible to do a pause by triggering an event case with while loop in it? And unpause then by terminating that loop?
Or would that mess up all sorts of things because events aren't meant to be executing for that long?
Message 5 of 12
(5,302 Views)
No, that's a really bad idea! Interactive loops never belong inside an event.
One possibility would be to keep the event timeout in a shift register and toggle form finite to infinite (-1) with an event. (example)
Message 6 of 12
(5,296 Views)
Sorry, where can I find this VI?
Message 7 of 12
(5,242 Views)
@altenbach
Well, I am programming a QMH, which has many cases (start, load files, run files and so on), the trouble I'm trying to resolve is this:
When I get on the case of 'Run Files', I want to implement a 'Pause Button' as if it were the 'Pause' next to 'Abort execution' in the toolbar (I´m not sure about the name of this Front Panel part), to be more specific, the Producer Part of the QMH is the same as all the QMHs examples, now, the Consumer Part of the 'Run Files' case, is conformed by 2 'For Loops', one inside the other, the first For Loop (the bigger), execute a 3 frames sequence structure, in the first frame of said structure is the second 'For Loop' (the smaller), it has another sequence structure to highlight some cells of a Table Indicator, so imagine that you has some spreadsheet and when you execute a code every line highlight at the moment each one was running, it will be yellow, the green; the 2 remaining frames of the BIG For Loop are not too important.
Message 8 of 12
(5,239 Views)
Hi Brot,
Then you should implement a proper statemachine!
Right now there is a pile of loops with a bunch of sequence frames - with no good option to place your "pause" feature anywhere!
Message 9 of 12
(5,232 Views)
Well your program architecture has to be designed to be paused from the beginning.
IMHO: The simplest architecture for this is an Event Driven State Machine (EDSM) then you could have a "Pause" state triggered by a button press.
=== Engineer Ambiguously ===
Message 10 of 12
(5,219 Views)
