キャンセル
次の結果を表示
次の代わりに検索
もしかして:
How to programmatically create a Strain Gage Calibration Wizard?
I have a requirement to build a Strain Data acquisition Systems using LabVIEW with all the Signal Conditioning Facilities available with PXIe-4331.
So the main attractive feature for the customer is the Offset Nulling and Shunt Calibration.
The DAQMX does have two VIs for this,   DAQmx Perform Bridge Offset Nulling Calibration.vi and  DAQmx Perform Shunt Calibration (Strain).vi
and both works very well..
But my problem is .. Customer is more interested in knowing the exact initial offset voltage  and the Gain adjustments made by Shunt Calibration vi.
The Strain Gage Calibration Wizard in MAX has the similar feature available.
But I couldn't find a way to implement the same in LabVIEW.
Any Ideas?
Thanks and Regards,
Mirash
Coding is a combination of intelligent and creative work - someone
0 件の賞賛
メッセージ1/3
5,024件の閲覧回数
Hello Mirash,
You can't run the DAQ Assistant's strain calibration wizard from your program, but you can query the offset and gain adjust programmatically through the API after performing the calibration:
AI.Bridge.InitialVoltage is the offset (in volts*) from the offset nulling procedure, and AI.Bridge.ShuntCal.GainAdjust is the gain adjustment factor from the shunt cal procedure.
* The PXIe-4331 doesn't actually measure volts. The PXIe-4331 performs ratiometric measurements, so AI.Bridge.InitialVoltage is based on measuring the voltage ratio Vch/Vex, then multiplying it by the ideal Vex value. The PXIe-4331 never measures Vch or Vex separately, only as a ratio. If you need to compare the initial voltage to an independent measurement (from another instrument), it is probably better to query AI.Bridge.InitialRatio, which tells you what the PXIe-4331 actually measured, then measure Vch and Vex independently and calculate their ratio.
Brad
Brad Keryan
NI R&D
メッセージ2/3
5,010件の閲覧回数
Mr. Brad Keryan
I am also working on the strain Data acquisition Systems using LabVIEW.
My problam is that is there any way to show the %error as show in the "MAX Wizard" using the  DAQmx (DAQmx Perform Bridge Offset Nulling Calibration.vi and  DAQmx Perform Shunt Calibration (Strain).vi).
I am using
NI cDAQ 9178
NI 9237 and 9945
Labview 9.0
Thank you
Kind regards
Shivam
0 件の賞賛
メッセージ3/3
4,689件の閲覧回数
