How to programatically pick a USB port
I'm using a device that plugs into the USB port and you can use the VISA commands (open, write, read, etc) to talk to it.  The VISA VIs need a device name and the device comes up like ASRL:X (where X is usually something like 5,6,7 etc).  I'd like to make a VI that will search through available devices to "find" the USB device.  Now I know I could  use a string ASRL:X and go through the numbers but I'd be going though things that aren't even there.  Is there a VI, command or something that will list available devices?
Chuck
(3,401 Views)
On the VISA Advanced palette (7.x), there is the function VISA Find Resource. As the on-line help mentions, you can specify something like ASRL[0-9]*::?*INSTR as the expression and it will return an array of resources. ASRL10 is typically the printer port so you may want to modify the expression.
(3,395 Views)
Thanks.  I had already written what I had thought of before which works fine but leaves you testing things that may not even exist.  Adding your suggestion will just make it that much better.
Chuck
(3,384 Views)
