How to programatically create UDL and DSN files from Labview
Can some one help me how to programmatically create UDL file and DSN file from Labview environment for windows database applications.
(3,652 Views)
A UDL is just a text file with the udl file extension. So, you can use Write to Text File. The example udl file that comes with the Database Connectivity Toolkit looks like:
[oledb]
; Everything after this line is an OLE DB initstring
Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\database\LabVIEW.mdb
The connection string is for an jet database (Access). The string for a more robust database such as MySQL or SQL Server is a bit different. I would suggest that you manually create a udl to see the format. You have not specified what it is you want to dynamically write to the udl file (db name, user, password, etc).
(3,635 Views)
