How to program labview
Some error handling would be good. As it is right now there could be errors being generated and you would never know what the error was or where it was being generated.
Beyond that, are there specific things you are concerned about?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(1,243 Views)
It will help us a lot if you attach the VI instead of an image.  Additionally, what hardware are you using to control this servo and what is the end goal of this application?
Message 12 of 13
(1,221 Views)
The servo is continuous what I want to do is slow down its velocity because this type of servo cannot be controlled by angles I need to do something in labview to slow it down. How it can be done by adding PWM block to control the pulse width and the duty cycle of the servo?
Message 13 of 13
(1,200 Views)
