How to program home switch?
I have a question regarding home switch programming.
I have a motor doing a sine velocity profile with two limit switches, one on each end. There is a third limit switch in the middle (the home switch) and I'd like to program somehow that no matter when I stop the vi and the motion of the motor that this motor comes back to the home position. Is there a way to program it to slow down nicely, since its going pretty fast so not to destroy equipment by stopping abruptly? and also how to make it find a way to home switch no matter which side of the switch it is? Im using a soft motion with 9012 on cRIO 9067.
Thanks in advance!
(3,110 Views)
Use the Find Reference Move block, look at the help file for details.
Ben64
(3,097 Views)
Thank you, Ill try it!
Regards!
Loras
(3,085 Views)
