How to program Slide Control visible items - digital display?
It is easy to trigger the visible items - "digital display" of a slide in front panel when it is not running. However, I tried to find the way to program the visibility for digital display but I couldn't find any. I am able to program the visibility for label, unit label and caption through property node, but not for "digital display". Can someone please help?
(2,776 Views)
Accepted by topic author veezien
This "flashes" the Digital Display (showing it can be turned on and off programmatically).
(2,760 Views)
It worked!! I didn't realize it can be programmed as it is. Thanks.
(2,745 Views)
