How to process the analog output of hall-effect sensors to determine gear RPM.
I am using a hall effect sensor to determine the rpm of my shaft. Attached to my shaft is a spur gear, and the sensor detects when the gear teeth passes it.
The attached pdf shows the "idle" state when there is no ferrous target detected.  And when a ferrous target (my gear tooth) is detected, a horizontal like is displayed.
I am using the NI-9229 device connecting my hall effect sensor to my PC.
I would like to know how I can process this signal so as to determine the rpm of my shaft in real-time.
Thanks and appreciate the assistance.
ST
(3,513 Views)
Hi, check this one out:
https://decibel.ni.com/content/thread/13337
Br,
/Roger
(3,509 Views)
