How to process individual element of array with individual element of another array
Hi to all
Can anyone tellme How to control an individual element of an array with another array of individual element.
i Attached Design.vi with this message..
In that if i select ch1 of channelsarray then v1 of voltagesarray should enabled accordingly..
similarly ch2->v2,ch3->v3,ch4->v4......
how to do this
which is the better way & tellme which control is best either cluster or array
my application is:
Data Acquisition System thru parallel port
this system is to acquire 64kbytes of data per channel & display it in graph(our own hardware)...
if anyone is having example.then it will b great help 4 me...
thanks in advance...
My New Year Wishes to all...
regards
jalal
Message 1 of 9
(3,669 Views)
I am not sure what you want, but take a look at the code I attached.
If you want to specify individual voltages per channel, there is no use for using check boxes anymore. Furthermore I would suggest a ring or enum instead of a listbox in the array.
aartjan
Message 2 of 9
(3,658 Views)
aartajan
first i will thank u..
sure...
i will send u Visual Basic exe file ....
u help me the same in Labview(project1.exe)
file is attached...
if particular channel is selected then only it should enable listbox
regards
jalal
Message 3 of 9
(3,651 Views)
aartajan
sure...
file is attached...
regards
jalal
Message 4 of 9
(3,652 Views)
Sorry, I do not understand what you are trying to say. I program almost exclusively in Labview, so I can't do anything with VB code.
aartjan
Message 5 of 9
(3,646 Views)
thank u
Message 6 of 9
(3,643 Views)
Okay, I misunderstood. I looked at the executable and found that it doesn't use arrays as your first LV exampled did. I attached the modified vi.
aartjan
Message 7 of 9
(3,643 Views)
i Thank u a Lot aartjan
it helped me a lot....this credit bcos of u only..(blongs 2 u)...
thank u once more..
bi
HAPPY & PROSPEROUS NEW YEAR
regards
jalal
Message 8 of 9
(3,623 Views)
Thanks for the compliments. I would like it if you rate my answer with stars 😉
Message 9 of 9
(3,616 Views)
