How to print the ActiveX DSO Control
I Captured  the Digital storage Oscilloscope(DSO)  image in labview using ActiveX Container.But I could not able to print the image in the control.I am getting a gray window only.I tried with
  1. Graphics Format vi's
  2. Report generation tool kit and
  3. VI Properties/Print options....
Is any other way is there to print and save it.?
(2,672 Views)
Take a screen shot (hit the "Print Scrn" key ont he keyboard).
Then open up MSPaint (type "mspaint" in the run command on the start menu).
Then paste (ctrl-V) the screen shot into mspaint.
Now print that. If you just get one big gray box or the like you may have an issue with your print driver (I mean LV isn't even in the picutre then) and should probably reinstall your printer.
-Taz
(2,659 Views)
