How to print a file?
How can I print a PDF file in LabView, without opening it, only giving the it's path?
(3,222 Views)
You can try using the report vi's. See example LV 8.6.1. Although I don't have a printer connected to this machine so I can't confirm it works.
(3,191 Views)
how to print a pdf file from LabVIEW
Found using a simple search.
Obviously you would need to update the path to the PDF reader based on whatever version you're using. If you're using a different PDF reader you should check if it has command-line options and adjust accordingly.
(3,182 Views)
Thank you very much, it worked.
(3,146 Views)
