How to prevent a moving XControl frontpanel
Hi
I createt for my application an XControl. When starting this app, I create a GUI how it is defined in a setupfile. This means all used Controls are positioned and sized dynamicly. Normaly this works fine. But my Xcontrol somehow moves inside its frame. It happens often that I can not read one ore more row or column. How can I fix this problem? I allready tried to precisly fit the windowframe to the frontpanel in the Facade.vi but I had no success. Is there an other way? After a build to a stand alone app the problem gets bigger.
Look at the zip in the appendix.
System: LabVIEW 8.0.1 on SuSE Linux 9.3
Thanks for your Help
codas
Message 1 of 1
(2,431 Views)
