How to plot scatter data with density-based color in LabVIEW?
I would probably set it to update the graph every n iterations or about once per second so we have something to look at. 😄
Message 11 of 14
(298 Views)
Yes, I've used nearly zero changes to original implementation (just to measure time spent). I did it in literally in two minutes before running to catch the bus, then left it to process the data overnight. 🙂
But if I try to update every Nth as you suggested (measured on 2M samples, some music and background stuff is running, so, it is a bit slower):
Message 12 of 14
(259 Views)
I am working on real-time processing on an FPGA, where I have to avoid making any such array.
Message 13 of 14
(197 Views)
Hi sonisatyam,
In the FPGA you don't have an UI and so you don't have any graphs or charts…
Or to put it the other way around: your data display stays in the host VI where you should have enough memory to handle larger arrays!
Message 14 of 14
(191 Views)
