How to plot points corresponding to a given pair of x,y values on a graph in real time?
Sorry again. I got it. Thank you very much. I was looking for a different file.
Message 11 of 15
(1,322 Views)
You are still using LabVIEW 6.0, so several "next versions" are already out! 😉
If yo want the graph to act as a chart so points are added as you go, you could accumulate your x and y arrays in a shift register as in the attached image. Make sure to add a delay and don't let it run forever because the arrays will grow without bounds. (The XY chart example uses a chart buffer for the same purpose.)
Message 12 of 15
(1,322 Views)
Hey guys , that was a very interesting conversation . It helped me solve my issue totally. Thanks and Cheers
Message 13 of 15
(1,315 Views)
I've the same problem
Message 14 of 15
(672 Views)
Hi 77,
Exactly the same problem as was written about 20 years ago?
And that 18 year old solution by Christian Altenbach does not work for you?
Message 15 of 15
(661 Views)
