How to plot multiple 2D arrays of data, with different x-values onto one graph
Hello!
So I am trying to create a piece of code that will take in multiple csv files of data (containing time (x) and amplitude (y)) and will plot all of them onto one graph. I am stuck on how to take the 2D arrays of data and plot them all on the same graph. Currently I am able to plot them all by using "Build Array" and taking the time portion from one of the files and using it for all of them, but the problem I have is that not all of my files have the exact same time column, or x-values (data points happen at different times). Anyone have any ideas on how I can do this? Thanks in advance!
(2,005 Views)
Hi ebohannon,
have you tried to use waveforms for your plots? (Or plots in a XY graph?)
This way each plot can use it's own timescale...
(1,987 Views)
Are the points for each dataset equally spaced? If not, you need an xy graph.
(1,967 Views)
That is what I am trying to do, but I guess I am just unsure on how to feed multiple sets of x-values to the waveform.
And to answer the other question, yes the data points are equally spaced, but some of the data sets are sampled at a higher frequency than others.
(1,912 Views)
Hi ebohannon,
If you would attach your VI with some example data we could tell you where you made errors…
So you can use (arrays of) waveforms…
(1,910 Views)
