How to plot curves on an intensity graph
I am writing a LabVIEW program for real-time spectral analysis of a camera. I want to draw spectral lines on the intensity graph in a one-to-one correspondence. I am not sure which properties to modify to achieve this functionality, and this is what I have tried so far. Thank you for your help.
(1,303 Views)
Accepted by topic author astro1024
We have absolutely no idea what you did to create your graph, so we cannot really give advice.
I would use mouse events to get the pixel and update the overlay using "plot images".
(very old example, there are many more)
(1,294 Views)
Thanks very much! Thank you very much!
I believe that I can solve the problem through your example.
(1,270 Views)
Hi!
I have a little confusion that I would like to consult. How to display and control the colorbar of an intensity graph in the VI in the example? I have tried but it cannot be displayed directly.
(1,190 Views)
Yes, something seems corrupted with that graph. I would create a new one.
(1,167 Views)
I have found a solution.
Right click the Intensity Graph, on the popup menu, => Visible Items, make sure both Z Scale and Ramp are checked.
(1,134 Views)
