I am using LabView 7Express. What I use is the "convolution and correlation" VI, without the 'Express' however ... I mean, if both my input signals are L-length, the result of the correlation will be 2L-length, i.e. the length is doubled. But I want to keep the original signal size, making the result L-length as well, and have the same time origin as the input signals. I mean, if my input signals are from 0-1 second, I also expect to see the cross-correlaton is within 0-1 second, having the same data points. Thanks a lot!
