How to plot circle with known radius and origin in XYGraph
Is there any method to draw curves or circles in XYGraphs with known radius and origin.
(22,140 Views)
Only if you know the curve formula, as circle is (X-x0)^2+(Y-y0)^2=R^2 you just have to implement this. Attached there's an example. I recommend you to see how it is done and think in other ways, cos it's the first sollution that came to my mind.
Hope this helps
(22,140 Views)
Sorry, I made some kind of mistake, center coordenates are not well done. Hope the concept gave you an idea.
(22,140 Views)
Use the formulas:
X = R cos(Theta) + Xo, Y = R sin(Theta) + Yo
to generate a set of points. The step size of Theta will affect how solid your circle is.
To plot them, you will need to initialize an empty 2D array, then fill in the spots for each point.
Bruce
Bruce Ammons
Ammons Engineering
(22,140 Views)
This code might help for plotting Circle or Arc
(22,140 Views)
Please declare conpi as singe
and value 4*atn(1) in vb
or user 22/7
(22,140 Views)
Please declare conpi as single
or user 22/7
use this code
Sub PlotCircle(graph As CWGraph, StartAngle As Single, endAngle As Single, radius As Single, H As Single, k As Single)
Dim i As Integer
Dim epoint As Integer
Dim xdata() As Double
Dim ydata() As Double
Dim radd As Single
Dim j As Integer
dim conPi as single
conpi=4*atn(1) ' or 3.14
' H , k Is center of circle and rad is radius
If StartAngle >= endAngle Then
radd = endAngle - StartAngle + 360
Else
End If
If radd < 0 Then radd = radd * (-1)
ReDim xdata(0 To CInt(radd))
ReDim ydata(0 To CInt(radd))
j = 0
For i = 0 To CInt(radd)
xdata(j) = H + radius * (Cos((StartAngle + i) * (conPI / 180)))
ydata(j) = k + radius * (Sin((StartAngle + i) * (conPI / 180)))
Next
graph.Plots(graph.Plots.count).PlotXvsY xdata, ydata
End Sub
(22,140 Views)
