How to plot a vertical line on XY Graph
Here's what I am talking about to keep the lines on the same plot. I also cleaned up your diagram a bit, removed some unnecessary code and put the stop button where it belongs in an event case.
Message 11 of 15
(2,246 Views)
I want to add another vertical line to my original plot, but I don´t want to get the old vertical lines removed by the new one. How do I set the interpolation off to append the new lines?
Thanks!
Message 12 of 15
(2,245 Views)
Right click on the plot legend. One of the options is interpolation. Select the first one - the one with no connections between points.
Message 13 of 15
(2,242 Views)
Hi!
I did the same code that you wrote, and I don't know why, the code didn't work.
Could you look at it and tell me the property that I didn´t set?
Thanks again.
Message 14 of 15
(2,232 Views)
You didn't do exactly like I did. You're not writing the new array to the shift register.
Message 15 of 15
(2,226 Views)
