How to plot a graph from text file?
This is driving me nuts!
I would like to plot a list of numbers in a text file to a graph. Each munber is on a new line, like this -
345
356
378
379
345
etc.
I managed to import the file and split it with the 'Spreadsheet to array' function but can't get much further than that.
Help would be much appriciated.
Ben H
(3,024 Views)
If you've split the string the way I'm assuming, this should do the trick!
If not, let us know and we'll get it fixed.
Message Edited by Will.D on 10-20-2006 02:35 PM
(3,007 Views)
You just need to use the Read From Spreadsheet function and wire a 'True' to the transpose input. Wire the 1D array output to a graph.
Message Edited by Dennis Knutson on 10-20-2006 12:40 PM
(3,005 Views)
Trumped by Dennis once more!
His was is much easier...
(2,996 Views)
Many thanks....it works now!
(2,989 Views)
