How to perform deconvolution using FFT
Hello Everyone
Is there anyone who knows the algorith or can provide me with a vi that shows how to perform deconvolution of two functions using FFT. In the labview help for deconvolution, the algorith suggested is.
  1. Compute the Fourier transform of the input sequence X * Y.
  2. Compute the Fourier transform of the input sequence Y.
  3. Divide the Fourier transform of X * Y by the Fourier transform of Y. Call the new sequence h.
  4. Compute the inverse Fourier transform of h to obtain the deconvolved sequence X.
i tried to do th same but didn't work. I am attaching a Vi in which first i convoluted a Square pulse with triangular pulse. Then i deconvoluted the convoluted signal using triangular pulse with the deconvolution tool given in labview. Then i tried to do the deconvoltion using the FFT algorith but didn't work. Is there anyone who has any idea on how to perform deconvolution using FFT.
Regrads
Chauhan
(6,618 Views)
I'm not sure if it's completely correct but it seems to spit out the right numbers.
(6,613 Views)
Hi Matt
Thanks for your quick help. Would it be possible to provide this vi for Labview 8.5. Actually i do not have Labview 9.
Regards
Chauhan
(6,589 Views)
Accepted by topic author Chauhan
Hi Chauhan,
This should work in 8.5.  Let us know if you still have trouble opening it.
- Greg J
(6,583 Views)
Thanks Friends
It helped me a lot.
Chauhan
(6,576 Views)
