How to pass data to a remote exe?
Accepted by topic author Gak
This probably explains the problem. VI server access for an executable is enabled in the .ini file that must be in the same folder with the application (at least until LV 8.6, I guess this didn't change for LV 2009).
If you have MyApp.exe, you need MyApp.ini in the same folder. It will be created if it doesn't exist.
MyApp.ini controls VI server access to MyApp.exe.
MyApp.ini should contain the following lines (can contain a lot more) for VI server to work:
[MyApp]
server.tcp.enabled=True
server.tcp.port=3364
server.tcp.acl="290000000A000000010000001D00000003000000010000002A10000000030000000000010000000000"
The acl (access control list) value above enables access from any machine. Check also this KB article for more information about the acl.
The port can be adjusted to your needs.
Message 11 of 13
(1,038 Views)
Hi dan_u,
Thank you for your help. I will try it and will let you know.
Thanks again.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 12 of 13
(1,020 Views)
Just to add, NI stopped support to data communication with remote LV application from LV8.2 onwards. If you check the ini of the application built using LV7.1, you will see the VI server strings for TCP communication in that. Also, to pass data to specific VIs in exe, you could also use "All VIs in memory" from invoke node for the reference of remote app and then pass on the desired values.
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 13 of 13
(978 Views)
