How to pass a string to Matlab
I'm trying to pass a string from Labview to a Matlab script node so that
matlab may open a the file named in the string. Does anyone have any ideas
as to how to do this?
Thanks!
Brad.
PS I tried converting the string to a byte array and passing it - but I
can't work out how to convert it back from a byte array into a string in
Matlab.
(3,274 Views)
You can use char(x) to convert the byte array x into astring in Matlab.
Good Luck.
Nx
(3,274 Views)
try using the "char" command in matlab
Brad wrote:
> Hi,
> Thanks!
> Brad.
> Matlab.
(3,274 Views)
