How to pass String Array LabVIEW Executable to (VB or) VBA
I am having a problem getting a string array from an LV app into the VBA procedure.
I am trying to "bullet-proof" (idiot-proof) an application to read some data
from an instrument and insert it on demand into cells of an Excel spreadsheet.
The user clicks a button on the spreadsheet and the VBA app (the client) gets
data from the VI executable (the ActiveX server).
The problem I'm having is that the array of strings appears to be empty.
I am using the VI.GetControlValue("StringArrayControlName").
The VBA code looks like:
'(this is a test program to do exactly the same thing,
' but using the time to generate the changing string(s) so that the data can be ~live)
' these
are global dims
Dim lvApp As AX_Time3RDR.Application
Dim VI As AX_Time3RDR.VirtualInstrument
Dim VIPath As String
Dim strTimeData(1 To 16) As String
' This is in a launch app subroutine. (on launch button clicked)
Set lvApp = CreateObject("AX_Time3rDR.Application")
VIPath = lvApp.ApplicationDirectory + "\" + lvApp.AppName + "\" + "AX_TimeRDR.vi"
Set VI = lvApp.GetVIReference(VIPath) 'this runs it too!
' this is in a read data subroutine (on read button clicked)
strTimeData = VI.GetControlValue("Time Data")
' this generates a VB compile error as is,
' but if I put an index on strTimeData, it only acts on the indexed element.
' Of course, the (MY) problem is that the returned data seems to be empty.
Sheet1.Cells(3, 4) = strTimeData(1)
Sheet1.Cells(4, 4) = strTimeData(2)
' and of course when I'm done, I quit the LV exe with
' on quit button clicked subroutine.
lvApp.Quit
I'm using LV 5.1.1 PDS and Excel 2K.
Dave Karon
Concepts NREC
(3,680 Views)
Ok so that was pretty dumb, BUT better documentation
WOULD have help me avoid this problem.
The answer is obvious. Well, maybe.
GetControlValue returns a Var, so the LV "To G" VI fixed the problem.
Dave
wrote in message news:3afafe9e@newsgroups....
> ' these are global dims
> lvApp.Quit
> Thanks
> Dave Karon
> Concepts NREC
(3,680 Views)
