> I need to have a scroll bar with different colors on it, such that the
> "bottom" bar is red then the one on top of it (half its size) is
> green. Is there an easy way of doing this? should I just place one on
> top of the other on the front panel? use clusters?
Depending on what you are needing, you should look either at layering
different sliders on top of one another, or you should look at the
different fill options and multiple thumbs/sliders on a single slide.
Greg McKaskle
