How to output a certain analog waveform by 9263
Thanks.
(2,439 Views)
Hi, could you please give some more details about what you want to get?
If you want to have Analog Output from Mulitple Channle, you can refer to this sample.
http://digital.ni.com/public.nsf/allkb/44F1067EA1893DF586256F4D001A1E14
If you look in the NI Example Finder, search for analog and scroll down to the Gen Mult Volt Update - SW Timed.vi as an example. Alternatively, you could do the DAC updates based on a hardware timer, then then use the software timer to calculate your square wave frequency.
(2,421 Views)
