How to open multiple files in Labview?
I want to open multiple files in labview by selecting multiple files,then read them? Can I do this in Labview 7.0?
Message 1 of 12
(12,110 Views)
You can use the vi example here to get multiple names:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=506500000005000000C7640100&HTHREAD=000091335&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Once you have the file names, you can use a for loop w/ a Read/Open file vi to open all the files.
2006 Ultimate LabVIEW G-eek.
Message 2 of 12
(12,108 Views)
Here's the windows way...
Wiebe.
"keiylh" wrote in message
news:5065000000080000000CCA0000-1079395200000@exchange.ni.com...
[Attachment Multi File Dialog.llb, see below]
Message 3 of 12
(12,109 Views)
Hi Wiebe,
Just downloaded this, modified it slightly, and changed it to LV 6.1 using the LV 7 Eval. Edition.
Excellent work.
Here's my version for anyone else whio wants it.
Cheers
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 4 of 12
(12,110 Views)
This works great...
Thanks!
MichelB
Message 5 of 12
(12,109 Views)
I have tested your code. Great work!. I need to open 612 files simultaneously, when I try to open this number of files they don't open.
Can you help me?
Thanks and Best regards.
Message 6 of 12
(11,696 Views)
What do you mean by "don't open" does it give an error of any sort or something like that. I ahve attached some code where I open 612 files write to them and close them. See what you can glean from it, and get back with me if you are still having problems.
Rick Kuhlman
Message 7 of 12
(11,669 Views)
Hi Rick,
Thanks for your response. I can't open your code because my version of LabVIEW is 7.1. Can you translate your code to 7.1 version?
If I use the library included in the post, I can open the dialog box and I can select multiple files, then I get an array that contains the paths of the files selected. Then I use a "for structure" to index the array and extract the files information.
So, If I tried to open less than 256 files, there is no problem, everything is OK, the array is full of paths information. But If I try to open my 612 files, the result array is empty, with no paths information inside the array.
Thanks you very much!. I hope you can understand my expressions, my english is not the best I would like.
Best Regards.
P. M. Aspas
Message 8 of 12
(11,639 Views)
Hi Rick,
Can you post your code saved for LV 7.1 ?
It ll be of immense help for me...
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 12
(11,463 Views)
Hello Partha,
Here's the code in 7.1 - good luck!
Janell R | applications engineer
Message 10 of 12
(11,433 Views)
