How to open multi-files at the same time on the Mac OsX
There is one example how to open multi-files at the same time but it is just for Windows.
But how to do it using Mac OsX?
Message 1 of 8
(3,357 Views)
I am not familiar with the Windows example you mention, but do use the Mac. How do you want to select the files to open? Do you have a list, or do you want to open all the files in a folder, or something else? Give us some specifics and someone will probably be able to suggest a soution for you.
Lynn
Message 2 of 8
(3,348 Views)
Opening multiple files (on any platform) is the same.
For i = 0 to NFiles - 1
Refnum[i] = Open File (Path[i])
{ Do stuff with open files - read this one, write that one)
Close File (RefNum[i])
Error checking is left as an exercise for the reader.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 3 of 8
(3,346 Views)
Lynn:
Here is the example for windows:
http://forums.ni.com/ni/board/message?board.id=170&message.id=142151&query.id=59085#M142151
It uses calls to Windows DLLs
CoastalMaineBird:
thanks, but with this method you have to choose the new file each time. You cann't chose 2 or more files simultaneously.
Message 4 of 8
(3,335 Views)
Sorry - you asked how to OPEN multiple files.
Steve Bird
Culverson.com
LinkedIn
Message 5 of 8
(3,329 Views)
If you want to CHOOSE multiple files in one dialog, I would write my own dialog.
You basically LIST FILES from the folder you want, put the names into a list box, and allow the list box to have 1 or more items selected. Then you get an array of indexes of which items are selected.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 8
(3,329 Views)
Good idea, thank you very much, i will try it!
Message 7 of 8
(3,326 Views)
It looks like that Windoze .llb simply creates an array of paths of the files selected by the user: text files, Word files, or all files. In a VI not included it apparently loops through the array of paths and opens the files. You can do all that with built-in LV file handling functions in a manner described by CoastalMaineBird above and the result should be platform-independent.
Lynn
Message 8 of 8
(3,322 Views)
