How to open a existing html report through labview
 Thanks in advance. Here i want to open and load the existing html report in labview (report is generated by teststand) find the attached report for the same.
Diana Mary.
(4,175 Views)
Hi Diana,
use this function to "open a HTML"…
(4,171 Views)
Hi GerdW,
 Thanks a lot. This function will open the report in browser, instead i want to read as a string in labview.
(4,116 Views)
I have a large number of html test reports that were created in TestStand that I want to post process (search through for data) using LabVIEW
(4,110 Views)
Did you try using the Read from Text File primitive present in File I/O palette?
(4,107 Views)
Yes i tried but can't able to read in the same html format.
(3,892 Views)
Hi Diana,
Why can't you?
Just display the read string after using ReadTextFile with your HTML file…
(3,888 Views)
