How to move a boolean button in a cluster control
in a program, i have to a boolean button in cluster control , in diamond shape. while moving it must show its movement also as i try to display in an image, which is attached with post.....
Prashant Soni
LabVIEW Engineer
(2,908 Views)
I don't understand.  Can you attach your vi?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,878 Views)
To move the button programmatically, create a Property Node of the button you want to move. Use the Position property (set to read) to get the current (starting) position, then inside a loop, use another Position property node (set to write) to add or subtract from the Left and Top positions.
Richard
(2,869 Views)
