How to merg MAX dll in to my Executable?
Do I need to worry about VISA components to run my application on a mechine which does not have MAX installed on it prior to run my VISA based Application build in LabView rev6.1. If I do need it installed can I merg it into my executable Setup Disk or installation package. Because, some on the mechines have older ver of MAX and In order to run applications build under LV6.1 it requires to have MAX wtih VISA-2.6.
(2,736 Views)
Yes, you do have to have NI-VISA installed if your programs uses it. You can get by with VISA run-time however and you can include it as part of your installer. The latest VISA run-time engine can be found here.
(2,736 Views)
