How to measure the pulsewidth ???
I tried to use the Timing and Transition Measurements block to find out the Pulse duration/duty cycle of the wave seen in the Waveform chart 3 in the Page 3 of the container, but i get an error saying that the histogram method is not suitable...
Can you suggest an alternate method to carry out the measurment ? Also please suggest the block that can be used for this purpose...? Thanks in advance and reply asap .....
(2,868 Views)
What are you using? any PXI card?
(2,847 Views)
Is it necessary that i should use a card ???
I am doing a simulation only...i need to detect the pulsewidth of the signal.
Also i need to know about the pwm generation block in LabVIEW..Is such a block available??
(2,827 Views)
(2,811 Views)
