How to measure the bandwidth of a signal automatically?
A signal waveform is shown in the front panel.I want to measure the bandwidth of the signal automatically.The detail is,first I find the maximum value of the waveform;then find half of the maximum points nearby;(there must be two points because the waveform is symmetrical.)last I calculate the interval of the two points--the bandwidth.The problem is perhaps there are many small waveforms in the graph.I only want to calculate the bandwidth of the maxmium waveform.
(2,675 Views)
I'm not sure exactly what you are trying to do. Could you clarify your problem a little? Thanks.
(2,675 Views)
