How to measure/plot data, and logg it on the different time intervals?
Hello!
I wonder how to implement different time intervals for plotting data on the chart/graph, and for logging? Using LabView 2015 SP1 .
For example: plot measurements every 1 second, but record only every 1 minute? Any examples / KB to read?
Thank you!
(1,936 Views)
Accepted by topic author YePererva
Hi Ye,
Have your loop iterate once per second to plot measurement data.
On each 60th iteration you also record data: you just need a case structure and Q&R (quotient&remainder)…
(1,910 Views)
Would it be still possible to bound those intervals with inputs to change those on the lfy?
(1,892 Views)
Hi Ye,
Yes.
(1,886 Views)
I found storing timestamp of the previous log and comparing with desired time interval to work better and give some flexibility.
(1,827 Views)
YES, this is the proper way to do something like this.
=== Engineer Ambiguously ===
(1,810 Views)
