09-07-2006 08:29 AM
09-07-2006 09:01 AM
09-07-2006 09:15 AM
09-08-2006 01:34 PM
Stephanie,
I was not able to find a way to lock the window without removing the title bar. If you want to go ahead with that solution, follow this link for a suggestion on how to display your program over the windows start button as well.
http://forums.ni.com/ni/board/message?board.id=170&message.id=52587&requireLogin=False
Otherwise, follow zou's suggestion with Gtoolbox. However, it is available only for LabVIEW 7.1, 7, 6.1, & 6.
Hope that helps!
Kalin T
09-11-2006 09:51 AM
09-14-2006 09:22 AM
Thanks everyone for helping me!
But it doesn't really help me much.... ![]()
I want to maximize the window (so in the Window Runtime position, I put "Maximize"). I want a title bar to show the name of the VI (I check the "Window has title bar" in the Window Appareance). I don't want to be able to resize the window (I uncheck the "Allow to resize window" in the Window appareance). When I do the last thing, the window can move and it's exactly want I don't want to do. If I uncheck this option, the user can click on the square and be able to resize and move the window.
Maybe there's an option somewhere in the proprieties that can disable moving the window? Why the window can move if I maximised the window and I can be able to resize the window? When it's a real maximize, the window can't move.
Except with the Toolbox (well, I can't use it anyway, because I have version 8.2), is there any other way to do this?
I'd like to have answers please (event if it's no
Thank you very much again
Stéphanie
09-14-2006 09:33 AM
09-14-2006 10:33 AM
09-14-2006 01:23 PM
