09-12-2025 08:21 AM - edited 09-12-2025 08:30 AM
Example 1:
"kind": "label",
"value": "this is the label"
Example 2:
"kind": "command",
"value": 32,
"step": 5,
"message": "message"
I was using the BlueSerialization package from blue origin. But am am running into this issue.
In typescript I can union between different interfaces and match on the "kind" value which is essentially a string enum.
https://medium.com/@meetpujara02/understanding-union-types-in-typescript-a-deep-dive-36b27eeae808
How can i mirror this behavior in labview? Essentially the payload is json and it can look different. What is considered best practice? In my case, I will actually be receiving an array of these payloads. Each one can be different in the array. How can i safely match on each to ensure the payload is valid?
thank you,
09-12-2025 11:30 AM
There is this JSON parser:
https://www.ni.com/en/support/downloads/tools-network/download.jsontext.html#405275
It includes a (limited) form of JSONPath to work with JSON.
I have not used the JSONPath portion of it personally but it sounds like that might be what you're looking for.
09-12-2025 01:10 PM
I think the JSONText library has JSON Schema support, which is intended to validate incoming JSON. I believe the JSON Schema enum type would do what you're looking for: https://json-schema.org/understanding-json-schema/reference/enum
09-12-2025 01:11 PM
Hi elibarber,
Union types do not exist as you have in TypeScript.
The closest I can see would be:
- A variant containing a cluster, specific to the kind of payload ;
- A string containing a flattened/binary version of the same cluster ;
- A class hierarchy with a subclass for each kind of payload.
I would personally choose the class hierarchy for scalability, but it can be a challenge for new LabVIEW users.
Attached is an example where I used the JSONtext toolkit function with a custom Object Serializer to deserialize an array of mixed type objects.
Raphaël.
09-16-2025 01:57 PM
Wow. Insane. OOP is not my strength with LabVIEW, but I was able to recreate or example with 30 classes for each command and it works!
Thank you, this is perfect. I know I will need need to plan for future payloads and this is should scale perfectly for when that time comes.
