02-23-2005 04:22 PM
02-23-2005 04:33 PM
02-23-2005 04:41 PM
@tst wrote:
If I understand you correctly, Your problem is with the gap (for example) between 11/04 and 11/08, right? You want the two points to be at the same distance from each other like the other points. If so, I think you'll have to go back to my suggestion - plot each point by its index in the array (the first point will recieve an X value of 0, the second point of 1 and so on), make the X scale invisible and place a string or an array in its place. The alignment I mentioned was of the string. If you use an array you shouldn't have a problem. If you use a classic array you can make the array itself completely invisible.
02-23-2005 04:57 PM
@tst wrote:
I don't think you can do this in the graph itself. I tried arbitrary spacing but that didn't help. You can place a string or a string array where the plot is and wire the data into that, but you'll have to align it somehow.
02-23-2005 05:10 PM
@Dennis Knutson wrote:
You're right. I That will teach to me to post an answer before verifying it. I apologize for that. I thought I've done this in the past. It might have been with relative time but I can't get month and day as an option for relative time. Let me play around a little and see if I can find a solution.
02-25-2005 02:45 AM
02-25-2005 12:18 PM
02-26-2005 12:00 PM
02-26-2005 06:00 PM
02-27-2005 01:34 AM
