How to make x-axis continue "forever"
Hello, I have the following labview VI (look at the file).
I am acquiring data from a data-acquisition board, and receiving the data in a chart in labview. However, when I run the program and receive the data in the chart, the x-axis only gives me data in the range of 0ms - 1s. How do I extend my range, so that I can practically keep receiving data for a very long time, instead of just 1 second?
If the program doesn't work for you I have also attached a picture.
(2,718 Views)
You have a graph, not a chart. Big difference! Maybe you want a chart which keeps the last N data points, scrolling forever as new data arrives, discarding the oldest..
In any case, "forever" will not fit, because you'll run out of memory.
(2,697 Views)
Alright that helped a little, but now I've run into another problem (see picture).
Now the time on the x-axis is really weird. How do I make it so the graph starts at 0 and then continue on from there, and not start at 3661317.... as it does on the picture.
(2,690 Views)
Accepted by topic author BirgerBrosa
Hi Brosa,
several things to change:
  • change formatting of the X axis to display timestamps
  • when using a chart you may also change x scale multiplier/offset
  • use waveforms (not DDT wires!) to handle timestamps easily
  • get rid of ExpressVIs when you want to get into less problems
(2,652 Views)
