How to make the projection on XY plane using 3D Scatter Graph
Dear Sirs,
I want to make spectra peak position distribution map on wafer.
I have made it using 3D Scatter Graph, but it’s not entirely that I need.
So I have some questions:
  1. In 3D Scatter Graph there is a “XY projection” option in the “3D Plot properties\Scatter\Projection\XY projection”. If one chose this option the projection on XY plane appears at 3D Scatter Graph along with 3D data points. The projection of data points on XY plane is absolutely that what I need. How to draw this projection only without drawing of 3D Graph?
  1. The 3D Scatter Graph in the XY viewing regime seems to be slightly convex at the corners. Like the lens. How to make it flat like projection to the XY plane.
  1. I would like to apologize for my bad English.
(3,159 Views)
Hi Sir,
can you provide example images of the graph you would like to achieve?
(3,154 Views)
