How to make the current value default programmatically
(4,051 Views)
Open a VI reference to the desired VI and use invoke mode with method: "Make current values default".
The VI cannot be running, so you need to set it from a different VI. (It also means, it cannot set itself.)
(4,040 Views)
You could always create your own "default" values by creating an .ini file. You can then save the values to the .ini file to change the default for the next run of the machine. The values are read in the initialization of your program and the values are written to the controls/indicators.
(4,032 Views)
