How to make the current value as default programmatically
Hi
     I attached a vi. In that we have 1 string control & 2 buttons. If i type some data in string control box & press OK means, it should change  the default value. Please tell me how to do this one.
If i close vi & open once again, and press the Retrive Button i should retive the last data entered in string box.
Thanks & Regards,
Harish. G.
(6,491 Views)
Hi!
You can take a look here:
https://decibel.ni.com/content/docs/DOC-16760
(It's not, stricty speaking, about changing the dafault value programmatically... but should help you anyhow)
Marco
(6,489 Views)
You can never set any control's (or indicator's) current value to default, if the VI containing it isn't in 'Edit mode'.
Programmatically you can set current to default using an invoke node...!! but again the VI should be opened in 'Edit mode'.
Now the only workaround is, whenever you want to set the current values to default.. write it to a file and then next time, populate the controls/indicators with the value stored in the file.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(6,460 Views)
