How to make state space equation in LabVIEW
I have obtained a mathematical model for a circuite in state space and want to put this equation in LabVIEW to test the model by giving it an input and read out put. It is simulation only.
Any idea how to do this?
Thanks inadvance for your help
Tareq
(2,902 Views)
The formula node is similar to C in syntax so I would try to copy it into that. If the code you have is in Matlab you might have to make some adjustments for functions that exist only in Matlab. Of course, if you are running Matlab on the same computer you can use the Matlab interface. Complicated math in G sometime makes more sense when it is put in a formula node.
(2,898 Views)
Hi
 by using MatLab it could be done. but I'm trying to make it using LabVIEW ONLY using the simulation pallet in LabVIEW. What I need is how to use state space function in that pallet to implement  X'=aX+b.
many thanks for your help.
Tareq
(2,894 Views)
