How to make several graph in one frame?
Hellow!
anyone can tell me how to make several X-Y graph in one frame so that  the boundary between each X-Y graph dissapear?
Thanks!
Message Edited by happybird on 10-31-2005 11:52 AM
(2,831 Views)
Perhaps you can just make the foreground of a single graph transparent.  Then, if you put them near each other, they look like what you are asking for.  You can put them in a bundle (see attached) so that they do not muddy up your wire diagram.
(2,814 Views)
Make the graph borders transparent then position the plot areas to build a single continuous frame. The attached vi does this progarmmatically, using property nodes. It also uses a decoration to mimick the graph border, easier to resize and position (and to change color...) than the original borders.
Message Edité par chilly charly le 10-31-2005 11:10 PM
Chilly Charly    (aka CC)
(2,808 Views)
